I'm using WICED Studio 6.1.0 and 6.2.0, and looking for source code named "eir.c". But there was an only object file, how can i get the source cod for that ?
Its internal files and source code is not available for customers.
Could you please let us know what you are trying to figure out? We may help you in some other way.
Also please mention which chip are you using.
Thanks & Regards,
Anjana
Thanks & Regards,
Anjana
If so where is the object file for eir, i can't find it.
As I said before these files are internal and we won't share it to customers.
Can you Please let us know why you need that object / c file?
Do you wanna realize any of BT classic application? If then, please let us know which BT profile or application you are looking for and which chip are you using. We can help on guiding you to develop your solution.
Anjana
