Studio Bluetooth
GHKC
New Contributor
hi sir/madam,
when i connected cybt-343026-01 evalution kit usb to windows 7 ports are not recognised. see the attachment.
thanks,
harikrishna g
SheetalJ
Hi Harikrishna,
Can you re-install the drivers in device manager? Try updating them automatically. Also, I assume you have WICED SDK installed in your system.
Check on any other system if board is being recognized. If yes, then there might be some driver issue with this system.
SheetalJ
Hi Harikrishna,
GHKC
New Contributor
if any driver application is there for installing drivers.
