Studio Bluetooth
          The log output is so messy through the UART COM port.  How can i avoid it???CatchDAA9.jpg
vsubbiah
Contributor
In TeraTerm try setting the NewLine Receive to Auto. If that doesn't help you can try the other settings to see which helps.
vsubbiah
Contributor
Try replacing all the occurrences of '\n' with '\n\r' in the entire code base.
