I am evaluating the CYBT343026 module and have a question.
I tried to send I2S data using BLE notification, but I2S data is unable to get from application, so I'm trying it without application.
Is it possible to send I2S data directly to BLE payload without going though the application such as HFP profile of Bluetooth classic?
- cybt343026
Hello @PixKM
CYW20706 I2S data is not accessible from application layer. I2S is used internally by the Bluetooth stack when using A2DP profile of BTClassic in application.
User have less access to I2S parameters as described in the blog here: https://community.infineon.com/t5/Resource-Library/PCM-I2S-Clock-setting-in-CYW20706/ta-p/246335
Anjana
Hello @PixKM
Anjana
Hello AnjanaM_61,
I got it, thank you for information.
