OSS/Copy Right of WICED API and Sample Application
TaGo_2353976
Level 4
Level 4
My customer will use sample application of WICED Studio, such as HandsFree profile of BT.
Q1: Is there any OSS source code inside WICED API and sample application code?
Q2: Is there any restriction of "Copy Right" when the customer use sample application code.
I'm sure Q2 is No but this is for double check.
Thank you.
--Takuya
Hi Anjana,
Thanks for your prompt response.
I understand WICED API/Sample app are never using OSS and there is no "Copy Right" of WICED .
Thanks again.
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
There is no restriction for using the sample applications.
Please go through the example application in WICED studio ( /20706-A2_Bluetooth/apps/demo/audio ) . You can refer either hci_handsfree example or headset .
Thanks & Regards,
Anjana
Hi Anjana,
Thanks again.
