I am using CYBT-343026-EVAL with WICED 6.2 now.
Could you tell me how many BT-Headset can pairing to this module at the same time?
If the number can change,could you tell me where can I change it?shjlaxel.lin_1746341goto-t_2353976user_437857088user_140663973
ispn:40226:1:0
l1:314:1:0
num_bond is a macro defination need to be added by yourself. You can define it with 10 for 10 paired devices' infromation to store.
You need to make some change with the function headset_save_link_keys and headset_read_link_keys if you want to save more pairing information. The following code is a snip about the function. The device can store a fixed number of bonding devices(parameter "num_bond" in the code). The new device will overwrite the old one if the size is full. Please modify your own code with the reference of the snip.
wiced_bool_t headset_save_link_keys(wiced_bt_device_link_keys_t *p_keys)
uint8_t bytes_written = 0, bytes_read;
wiced_result_t result;
uint8_t nvram_id = HEADSET_NVRAM_ID;
wiced_bt_device_link_keys_t keys;
uint8_t i=0;
uint8_t device_saved=0;
uint8_t device_id=0;
// there might be a situation where the keys are already saved, for example in dual mode
// device the br/edr keys can be present when we are doing le pairing
for(i=0; i<num_bond; i++)
bytes_read = wiced_hal_read_nvram(nvram_id+i, sizeof(wiced_bt_device_link_keys_t), (uint8_t *)&keys, &result);
WICED_BT_TRACE("keys.bd_addr:%B p_keys:%B keys static:%B p_keys:%B\n", keys.bd_addr, p_keys->bd_addr, keys.key_data.static_addr, p_keys->key_data.static_addr);
if ((bytes_read == sizeof(wiced_bt_device_link_keys_t)) &&
(memcmp(p_keys->bd_addr, keys.bd_addr, BD_ADDR_LEN) == 0))
WICED_BT_TRACE("Device address already exist: %d", nvram_id+i);
bytes_written = wiced_hal_write_nvram(nvram_id+i, sizeof(wiced_bt_device_link_keys_t), (uint8_t *)p_keys, &result);
device_saved=1;
break;
if(device_saved==0)
wiced_hal_read_nvram(nvram_id+num_bond,sizeof(uint8_t),(uint8_t *)&device_id, &result);
bytes_written = wiced_hal_write_nvram(device_id+nvram_id, sizeof(wiced_bt_device_link_keys_t), (uint8_t *)p_keys, &result);
WICED_BT_TRACE("Saved %d bytes at id:%d result:%d\n", bytes_written, device_id, result);
device_id++;
if(device_id >= num_bond)
device_id=0;
wiced_hal_write_nvram(nvram_id+num_bond, sizeof(uint8_t), (uint8_t *)&device_id, &result);
return (bytes_written == sizeof (wiced_bt_device_link_keys_t));
// try to figure out what is being updated
// if (p_keys->key_data.le_keys_available_mask != 0)
// WICED_BT_TRACE("updating LE keys\n");
// keys.key_data.le_keys_available_mask = p_keys->key_data.le_keys_available_mask;
// keys.key_data.ble_addr_type = p_keys->key_data.ble_addr_type;
// keys.key_data.static_addr_type = p_keys->key_data.static_addr_type;
// memcpy (keys.key_data.static_addr, p_keys->key_data.static_addr, sizeof(p_keys->key_data.static_addr));
// memcpy (&keys.key_data.le_keys, &p_keys->key_data.le_keys, sizeof(p_keys->key_data.le_keys));
// else
// WICED_BT_TRACE("updating BR/EDR keys\n");
// keys.key_data.br_edr_key_type = p_keys->key_data.br_edr_key_type;
// memcpy (keys.key_data.br_edr_key, p_keys->key_data.br_edr_key, sizeof(p_keys->key_data.br_edr_key));
// WICED_BT_TRACE("Saved %d bytes at id:%d result:%d\n", bytes_written, nvram_id, result);
return WICED_TRUE;
* This function is called to read keys for specific bdaddr
wiced_bool_t headset_read_link_keys(wiced_bt_device_link_keys_t *p_keys)
uint8_t bytes_read;
uint8_t i;
uint8_t find_flag=0;
bytes_read = wiced_hal_read_nvram(nvram_id+i, sizeof(wiced_bt_device_link_keys_t), (uint8_t *)p_keys, &result);
find_flag=1;
return (bytes_read == sizeof (wiced_bt_device_link_keys_t));
if(find_flag == 0)
return NULL;
num_bond is not defined in your change.
Where should it be defined and what number should it be defined?shjluser_437857088goto-t_2353976
Whether I can change max number of pairing device if I changed my own code to your upon code .
I have tried some way to change Max number of pairing device.
I changed here.hci_control.h:Line:79
[#define HCI_CONTROL_AG_NUM_SCB 2 /* Max simultaneous connections to HFs */]
I changed HCI_CONTROL_AG_NUM_SCB from 2 to 1.
The result is CYBT-343026-EVAL can only pair to 1 device only at the same time .
Then I changed HCI_CONTROL_AG_NUM_SCB from 1 to 3.
The result is CYBT-343026-EVAL can not pair to 3 device,it just can pair to 2 device only.
I guess there is a restriction exits somewhere.I am finding it.
Do you know it?shjlgoto-t_2353976user_437857088user_140663973
