i'm looking for a Bluetooth Module.
CONDITIONS
・SPP required
・Version 4.2 or higher
・Smart Ready compatible (Classic +BLE)
・15mm×24mm×2.9mm or less
I found these as candidates.
・CYBT-423028-02
・CYBT-413034-02
However, I did not understand the specification of "WICED" in detail.
Do you have a detailed document on "WICED"?
I am waiting for an answer.
Please go through our getting started appnote to get familiarized : https://www.cypress.com/documentation/application-notes/an223400-getting-started-ez-bt-wiced-modules
You may also go through our WICED Academy files: GitHub - cypresssemiconductorco/CypressAcademy_WBT101_Files: Files for WICED Bluetooth 101 class
Anjana
Anjana
In addition, there is a SPP sample app in the SDK and so you can try it out. Do remember to install the platform files for your
modules.
Use SDK version 6.2.1 for the time being, as there is some bug in the latest 6.4.
