Studio Bluetooth
user_1881301
New Contributor II
hi!
for BLE we are using the CYBT-343026-01 with the Wiced EZ-serial firmware
1) can the EDR functions of the CYBT-343026-01 be used when the module is programmed with EZ-serial ?
2) is there a manual for the EDR setup and use of the CYBT-343026 ?
Thanks in advance
Viggo
AnjanaM_61
Hi Viggo,
Yes, BT classic can be configured . But only SPP profile is supported as of now.
Please check 3.3 Cable Replacement Examples with SPP in EZ-Serial WICED Firmware Platform User Guide for CYW2070x-based Modules
https://www.cypress.com/documentation/software-and-drivers/ez-serial-ez-ble-module-firmware-platform
Anjana
AnjanaM_61
Hi Viggo,
Anjana
user_1881301
New Contributor II
Hi Anjana,
thank you for the quick answer.
I found the SPP in the manual.
Viggo
