hi Cypress:
We only want to run controller firmware on cybt-343026, but not the protocol stack on bluetooth chip.May I ask if this controller firmware can be provided? How to burn to the cybt-343026-eval development board? TKS;
ispn:40226:1:0
l1:314:1:0
Hello David,
Thanks for contacting Cypress Technical Support.
BT stack of CYBT-343026 is already included in the ROM code.
However you can run BT stack on any other host like any micro controller/Linux/Android and can send directly HCI commands to CYBT-343026 device via HCI UART.
HCI UART pin details are given in the datasheet here: https://www.cypress.com/documentation/datasheets/cybt-343026-01-ez-bt-wiced-module . However you may need to program it initially with firmware / patches .
Programming options are detailed here: https://community.cypress.com/docs/DOC-14990
Getting started appnote for reference : https://www.cypress.com/documentation/application-notes/an223400-getting-started-ez-bt-wiced-modules
Thanks & Regards,
Anjana
Hello David,
Thanks & Regards,
Anjana
