KeTa_1341526
Level 5
Level 5
Distributor - TED (Japan)
10 likes given 10 likes received 5 likes given
How can I debug CYBT-343026-EVAL with Modus 2.5?
I do not have MiniProg3/4 and JLINK.
Can I debug without the above emulator?
Takahashi
Yes, you are correct. Please use the HCI UART for SWD debug.
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
I am sorry the answer is no. Please refer to the AN for details: https://cypresssemiconductorco.github.io/btsdk-docs/BT-SDK/WICED-Hardware-Debugging.pdf
You can only use the trace log for your debug if you don't have the emulator.
KeTa_1341526
Level 5
Level 5
I got MiniProg4.
I want to do [5.2 Using the Eclipse IDE for Modus Toolbox] in the following document with MiniProg4, CYBT-343026-EVAL, and Modus.
The document uses CYW20819-EVB, so there is a SWD, but CYBT-343026-EVAL does not have a SWD.
Looking at [9.3.1 SWD Debugging with the HCI UART] in the following document, it seems that SWDIO is connected to HCI_UART_RXD and SWDCLK is connected to HCI_UART_TXD.
CYW920706WCDEVAL Hardware User Guide
Similarly, should I connect Miniprog4 and HCI UART Port?
Best Regards
Takahashi
