Studio Bluetooth
     How do I get the audio data when the BT conencted the iphone ? I want to know the API
Refer to hci_handsfree example. You can use the wiced_bt_sco_setup_voice_path() API and set path to WICED_BT_SCO_OVER_APP_CB and provide the data callback. In this callback, you can modify the data samples as required.
Are you using HFP or A2DP? The PCM samples can be routed to I2S or to APP. Refer to the A2DP_sink example or headset example.
I'm using the HFP. It is a secure encryption project. I need encrypt audio pcm data or decrypt the data.so I need get the pcm audio data
