Studio Bluetooth
Jede_4569591
New Contributor
I cannot find any documentation or questions on connecting two boards with Bluetooth Classic.  This seems like a pretty basic use case, so I think I am just missing something. Can someone point me towards some documentation, or towards an example project? I am looking to connect with the Bluetooth Classic SPP profileand I am using the CYW920719Q40EVB-01 evaluation boards.
I have successfully run the examples in the WICED SDK as well as Cypress Academy's WB101 Bluetooth class on github.
Thank you for the help.
NRCH
New Contributor II
I found that using "hci_audio_gateway" demo as client and "spp" snip as server, I was able to connect two CYW920719Q40EVB-01 to each other using SPP. Use the host "ClientControl" app to configure the connection by the spp-tab.
