TaGo_2353976
Level 4
Level 4
I tried following procedure.
1. Place installer 6.2.1.2 and .eml file to C:\
2. Run and install it to default directories.
However, I encountered following issues.
<Issue>
-There is no CYBT EVAL platform,such as CYBT-343026-EVAL.
-There is NOT "handsfree" demo application.
We could see both of them in ver6.1 so I'm confusing.
MichaelF_56
The platform files are here: Platform Files for CYBT-343026-EVAL – KBA221025
The Hands Free app may have been removed.
MichaelF_56
OK, thanks .
Regarding to Platform, the customer should place platform file that is download from your web site in the WICED studio install directory manually.
Regarding to Hands Free app, can we copy the sample application from older WICED studio version,such as 6.1 then build and use it ?
The sample app from an older version of the SDK should work.
Not all platforms are included in the WICED installation by default like CYBT-343026-EVAL.
As the previous reply suggests you can get the sample app from an earlier version of WICED, but the support and updates for it will be negligible.
Winston
