Nov 27, 2019
08:40 AM
Nov 27, 2019
08:40 AM
During the loading of an application to the CYBT-343026 module (20706 based), are there any parameters that can be given to Chipload.exe to set the BDADDR of the module? The application is based on the headset demo app.
11:13 PM
Nov 27, 2019
11:13 PM
Hi Corey,
There is no option to add Bt address in chipload.exe ( Programming using ChipLoad.exe )
You may need to add the address as BT_DEVICE_ADDRESS=112233445567 in build make target and pass the hex file to chipload
Thanks ,
Anjana
11:13 PM
Nov 27, 2019
11:13 PM
Hi Corey,
Thanks ,
Anjana
