YoJa_3107936
Distributor - Macnica (Japan)
100 sign-ins 50 sign-ins First like given
Hi
When accessing Flash, you could tell me the read speed and write speed?
Y.Jiang
GauravS_31
10 questions asked 250 solutions authored 250 sign-ins
From the STM32F411 datasheet, the maximum flash access speed is 100 MHz. You can refer to platform_config.h to check the PLL settings for flash clock speed as well as internal flash wait state.
GauravS_31
I believe this information should be available in the flash datasheet.
GauravS_31
