Is including a JTAG/SWD interface in a CYW20719 PCB design recommended?  I learned that flashing and debugging can be done with the UART, but just wanted to get a second opinion if somebody thinks that programming/debugging application code with an external debugger is easier or maybe a safe backup to UART.
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
The JTAG interface is avaliable in CYW20719. Please refer to the document in the WICED SDK which is located in the 20719-B1_Bluetooth/doc file: CYW207x9-JTAG-Debugging.pdf and CY9207x9WCDEVAL-Schematic.pdf.
We recommand you to program and debug with the HCI UART.
Owen_Zhang123
What document in WICED should we refer to for programming the CYW20719  chip in our own design and doing testing?
The device is usually programmed through the HCI UART. You can refer to the CYW920719Q40EVB_01-BaseBoard-Schematic.pdf, CYW920719Q40EVB_01-CarrierBoard-Schematic.pdf and CYW9207x9WCDEVAL-Schematic.pdf for your design.
For the test, you may refer to the mbt tool in wiced_tools/mbt. Refer to the readme.text for how to use the mbt tool.
