Studio Bluetooth
deonc_3697476
New Contributor II
Is  RFLDO_VDDOUT supposed to be an output? I checked the datasheet and on page 16 it says it is an output. But on this website SnapEda it says that an error is: Symbol pin RFLDO_VDDOUT's type should be set to 'Input' or 'Power', but it is set to 'Output' . So I am assuming the SnapEda's error is wrong and that the RFLDO_VDDOUT type being set to Output is correct?
https://www.snapeda.com/parts/CYW20719B1KUMLG/Cypress%20Semiconductor/view-part/?ref=search&t=cyw207...
Owen_Zhang123
Yes, the RFLDO VDDOUT is the output of the RF LDO. It is an output pin.
Owen_Zhang123
