Studio Bluetooth
JiZh_4619191
New Contributor II
How to download code to CYW20719 On Chip Flash with WICED?
SheetalJ
Hi JiZh_4619191​,
The Wiced SDK will download the application to the flash. But it will not display that in the console window.
If you can run the application after reset, it indicates the application has been programmed to the flash.
SheetalJ
Hi JiZh_4619191​,
