towa_2281366
5 sign-ins First solution authored First reply posted
We had encountered the same problem as the  following post:
https://community.cypress.com/t5/WICED-Studio-Bluetooth/CYBT343026-I2S-WS-signal-level-and-L-R-chann...
But there is no bug-fix-patch attached, can anyone tell me how to fix it ?
(sdk : wiced 6.4)
It's urgent, thanks!!!
The issue is confirmed to be existing in current SDK and has been reported. Please wait until the issue is fixed in future versions.
Charles_Lai
500 replies posted 250 solutions authored 250 sign-ins
How are your kit's pin configuration and deployment? How do you test and confirm that you have the flipped results?
pin configuration:
I2S_BCLK:I2S_CLK/PCM_CLK/P2/P37/P28(B7)
I2S_WCLK:I2S_WS/PCM_SYNC/P0/P34(C8)
I2S_DOUT:I2S_DO/PCM_OUT/P29/P3/P35(A8)
I2S_DIN:I2S_DI/PCM_IN/P12(C7)
test:
20706: working as a2dp source and i2s master ,start a2dp stramming with api:
wiced_audio_start(TRUE, AUDIO_ROUTE_I2S, media_cid, &sbc_caps_configured )
Capture I2S signal using saleae logic  while 20706 trasmitting music to remote headphone, only feed i2s with left channel data ("0" when WCLK is high), in the meanwhile, headphone's right  channel has sound out (should be left channel)
