Studio Bluetooth
ilHw_4713311
New Contributor II
Hello.
One of my goal is sending data from PUART to rfcomm(SPP).
In my previous project with CSR support bypass mode(PUART -> SPP) but Cypress don't have such features in my Study.
So I'm working on Bypass mode(PUART->SPP) by myself.
My Request.
I know you support thread APIs and Mutex.
But I want to make sure that CYBT-413034 receive data via PUART while SPP is sending at the same time. (multi thread)
Please give me any advice.
SheetalJ
Hi ilHw_4713311​,
Can you please have a look at Exercise 6A.2 in Classic Bluetooth-Basic pdf here- CypressAcademy_WBT101_Files/Labmanual at master · cypresssemiconductorco/CypressAcademy_WBT101_Files...
I think this is what you are trying to achieve.
ilHw_4713311
New Contributor II
Hello.
Thanks for your reply.
What I found from link is about "6A.2 Service Discovery Protocol(SDP)".
CypressAcademy_WBT101_Files/WBT101-06A-ClassicBluetooth-Basic.pdf at master · cypresssemiconductorco...
I'm wondering if you could tell me that I can send data via SPP(rfcomm) and receive PUART at the same time.
ilHw_4713311
New Contributor II
I'm testing receiving data from PUART and sending it to SPP(rfcomm).
Test 1
Receive data via PUART only (baud rate 460080)
Test 2
Send data via SPP only
Test 3
Send data via SPP as well as receiving data via PUART
I'm experiencing Test 3 SPP transfer speed is very slow than Test 2.
That's why I made this case.
SheetalJ
I pointed you to the 'Exercise 6A.2 Add UART Transmit' (page 26). Please check that.
ilHw_4713311
New Contributor II
I reviewed your link. Unfortunately, that is not I expected.
I will do more test by myself. Then ask you again.
