Studio Bluetooth Forum Discussions
SanjeevK_06
5 replies posted 5 sign-ins First solution authored
I am looking for some I2C Salve examples for this module. The application is to use this BLE device as Prxomity detector using RSSI from a tranmitter. So i want to configre this module more like a EzI2C slave which we do in capsense. I see some examples for I2C master with CYBT - 343026, but non on I2C slave.
Owen_Zhang123
Moderator 500 solutions authored 250 sign-ins 1000 replies posted
The CYBT-343026 is based on CYW20706 device. It only support as a I2C master. If you need a I2C slave function, you need to accomplish it with the GPIO to emmulate it. Or you can use the UART port.
Owen_Zhang123
SanjeevK_06
Do we have any bit banging examples?
Owen_Zhang123
Sorry, there isn't bit banging examples. You may check the GPIO example for reference.
