hii Madam/sir,
Currently i am working on cybt-343026 module. For Testing purpose spp(example project) downloaded into cyw920706 evaluation board it is working as expected then same program i downloaded into cybt-343026 module through cyw920706 evaluation board. But after downloading sucessfully module not advertising.
can any one give solution for this.
Hello HaGo_4718696,
>>I did not understand what do you mean by this.
I would suggest you to try demo.hello_sensor example first. Use the Make Target to download default example to CYBT343026 eval board
demo.hello_sensor-CYBT_343026_EVAL download UART=COM39
where COM39 is the HCI UART port.
You should be able to see the hello sensor advertising in your mobile/laptop using CySmart or any other bluetooth application.
Hello HaGo_4718696,
