Studio Bluetooth
OrAs_4645701
New Contributor II
I have a control on my phone using client control, but I didn't succeed to connect to the audio channel.
I tried to use Android phone, but it connect and disconnect shortly after.
With IPhone I get the following error:
client control- AG Response: ERROR Num: 0 Params:
SheetalJ
The audio operation implementation is not there in the code. Therefore, it doesn't work.
SheetalJ
Hello OrAs_4645701​,
Can you please let us know the WICED version and demo app you are using?
Also, how much baudrate are you setting in ClientControl?
OrAs_4645701
New Contributor II
Hi
It's 6.4
I am using 115200 baud rate,
OrAs_4645701
New Contributor II
Demo app is
snip.bt.hci_handsfree
SheetalJ
Hello OrAs_4645701,
Unfortunately the audio functionality in handsfree demo app does not work with WICED 6.2 and 6.4. This issue should be fixed in next WICED version, can't promise though. Our sincere apologies for the inconvenience caused.!
OrAs_4645701
New Contributor II
Doesn't work on 6.1 also, so it suppose to work at all ?
SheetalJ
Yes it will work. Just that there is some gap in implementation from our side in WICED apps.
OrAs_4645701
New Contributor II
Ok, so whay I can't her the sound throw PC using Client Control ?
SheetalJ
