I am using a CYBT-343026-EVAL board.
I prepare it donwloading the application "CYBT-343026-01 WICED EZ-Serial FW Image V1.1.14".
The application starts and I see the text command interpreter on the PUART interface.
I see no command interpreter on the HCI UART interface.
Can I enable the ""CYBT-343026-01 WICED EZ-Serial FW" application to expose the command interpreter
on HCI UART too?
If not, is there a ready to use application for this purpose?
Hi GiGu_4666771 ,
For CYBT-343026 Ez-Serial FW, HCI UART is enabled only for reprogramming the device.
PUART is used as command interface.
You may refer to user guide available here: https://www.cypress.com/file/455966/download
Note : You can also use WICED SDK IDE to develop your own application as per requirement
Anjana
Hi GiGu_4666771 ,
Anjana
