Hi
Customer is confirming Mode 1 ~ 9 described in Mode of Operation on page 9.
From Lab file [1752099R-RF-MIC(BT 3.0)-EZ-BT Module-CYBT-343026-01;CYBT-343029-01;CYBT-143038-01-V1.0.pdf]
Could you tell me what kind of settings are output for these modes?
Would you be able to contact us ASAP?
Yang
You can use CyBluetool (Windows Installer) to allow DUT to enter these modes for regulatory test.
Check for the commands E_Receiver_Test_[v1], LE_Receiver_Test_[v2], LE_Transmitter_Test_[v1], LE_Transmitter_Test[v2].
Hi Yang,
I am not able to find the file you have mentioned. Can you please provide the attachment or provide some link to get more details about this?
If this is a high priority critical query, I would suggest you to contact your local Cypress team, the team can help you with getting faster response with the solution.
