RiHe_4599321
5 replies posted First question asked First reply posted
We are integrating a CYBT-333032-33 Module onto an MSP430 Design.  Can I get the confirmation that these pins (disregard Column 3, that is internal for us) are appropriate for EZ Serial Interface and Control?
Also, on initialization I can expect the Initialization burst message to come in on the UART_TXD line/pad per the EZ-Serial Spec.  At 115.2K.  This is our confirmation of a functional interface and we will first check it on a scope.
Richard Hecht
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi Richard,
I am afraid you have selected wrong BT UART pins. Please refer Table 4 in CYBT-333032 datasheet https://www.cypress.com/file/464611/download.
Pad 20, 16, 17 & 18 are dedicated for HCI UART pins. For PUART, please select
Pad 15 (P4) as PUART_RXD,
Pad 14 (P31) as PUART_TXD,
Pad 2 (P3) as PUART_CTS,
Pad 19 (P30) as PUART_RTS.
SheetalJ
Hi Richard,
That Table and Pinout declaration / application of pads 14/15 is very confusing, but yours is correct ... Thanks.
