About writing function to NVRAM of CYBT-343026-01
NAYU_1212731
First like given
Hi.
Our project is doing a design with Bluetooth module of CYBT-343026-01 now.
Software uses "hci_audio_gateway" of WICED-Studio-6.2.
So I have a question about NVRAM.
1. I'd like to know the write limit counter to NVRAM when using the 'hci_control_write_nvram()' function.
2. I'd like to know a product name of NVRAM and the product number.
Thank you.
The module uses FM25Q04 sflash which can support 100,000 program/erase cycles.
TaGo_2353976
Level 4
Level 4
>Cypress team.
The customer needs to know how many times NVRAM can be written and NVRAM part number.
Please let me know.
>Nakagawa-san,
Could you tell me the back ground why you need to know it ?
Thank you.
--TAK
Thank you for you support.
I'd like to use fixed NVRAM_ID with our design.
In other words, data is written in the fixed address.
I'm anxious that I come to have the short life of NVRAM.
日本語を併記します。
私たちの設計では固定したNVRAM_IDを使用したいです。
つまり固定したアドレスにデータを書き込むことになりますが、
NVRAMの寿命が短くなることを心配しています。
Thank you.
y.naka
y-naka,
