Studio Bluetooth
Can you confirm that we can NOT use the ADC Audio Mode with the CYW20719 Dev Kit (CYW920719Q40EVB-01) ?
I guess it is impossible because the dev board is equip with a CYW20719 - 40 QFN package (CYW20719 and CYW20735 Analog to Digital Converter(ADC) ).
Thank you,
Thibaut.
ShengY_96
As the link (CYW20719 and CYW20735 Analog to Digital Converter(ADC) ) mentioned:The Audio mode (micn and micp pins) is not available in the 40 pin QFN package of the CYW20719.  The CYW920719 use the 40 pin QFN package, so it not supported ADC Audio Mode.
ShengY_96
