I tried to test the LE OTA Apps for Android, which is in .\WICED-Studio-6.4\common\peer_apps\ota_firmware_upgrade\Android\LeOTAApp\app\build\outputs\apk\app-debug.apk.
By the way, when I "Connect" button to search target LE device, the Apps is down(killed). The issue was always reproduced on my side. For your information, I tested it with Android 9 and 11 version and the test results was same.
I am not sure if the issue is known issue. If so, could you release patched Apps for Android?
One more thing, I also tested with LE OTA Apps within Modus SDK, but it's also killed.
Liam
WICED Studio Bluetooth
I couldn't reproduce such issue. I have tested it in Android 6 and Android 11 version. No crash observed. I used Generic BLE server as peer device. Eg: hello_Sensor app. May I know which peer device you have used for your test?
Also, Please try to test with Windows version of the same app also. If you observe the issue only with android app, Please collect and share the android debug logs with us.
-Dheeraj.P.K
Could you please use the android app from the github and try the same experiment?
https://github.com/Infineon/btsdk-peer-apps-ota
-Dheeraj.P.K
Hi Dheeraj.P.K
As you said, I tried to test with the Android Apps(LE OTA) from github but still happened. That is, the Apps also is killed when I click "Connect" button.
Liam
-Dheeraj.P.K
Hi Dheeraj.P.K
Thanks for your update. I already verified it worked fine with Windows version. Let you know Android version info. soon.
Always thanks,
Liam
Hi Dheeraj.P.K
As you said, I verified "LE OTA Apps" worked fine with Android 12.
Always thanks,
Liam
Hi Dheeraj.P.K
I am not sure if you have tested with iOS. Our customer is trying to test with the Apps on the github above. According to customer, the connection is done successfully but OTA f/w upgrade is always failed. If needed, I asked customer to update more detailed information here and he will give more information soon.
Liam
