Dear ALL,
the datasheet says the supply voltage can be extended up to 28V.
what is the trade off? the datasheet does not mention any further application notices about this.
I guess the inductive load capability maybe reduced due to the higher input voltage.
looking forward your feedbacks.
thank you.
The device can operate in the extended supply voltage range, but we do not guarantee all parameters described in the datasheet below 8V and above 18V, they might vary.
Anshika
Anshika
Thank you, Anshika.
I get it.
