puart receives wrong value
prvoc_2175136
I am trying to communicate to BCM20737 tag board with peripheral uart. I followed the puart functionality from puart_contorl example
Also what I send to terminal using puart_print/puart_write is displaying correctly. So I think the setup is correct.
The problem I see is what ever value I receive from puart_read is not same as value I send from terminal, please let me know what can be the reason for this behavior.
FYI : I have set the same baud rate on PC and BCM20737
Can you post a snippet of the source code where you are reading the received bytes?
I just tested your scenario with puart_control app in the SDK and I was reading correct values from the terminal.
Using the following code from puart_control:
Using Tera Term, I was pressing 'c''s and whenever I did I saw this debug traces from SDK.
Please let us know if you were able to solve your problem. Thanks.
James
BoonT_56
Are you using the clientcontrol.exe SW on your PC for this exercise? And despite following the procedure described in "PUART-control.pdf" you are still seeing the above?
praveen
James
