Smart Bluetooth
Can a single 20732 (peripheral) be connected to more than one piconet master (central) at the same time?
That is, can multiple piconet masters (centrals) simultaneously access the same slave (peripherals)?
QUESTION 2:
Can one 20732 that is piconet master (central) of a 2nd 20732 slave (periphal), and at the same time advertise to and connect as slave with a 3rd 20732 master (central)?
VictorZ_46
This functionality is not supported on 20732.  20736 supports both scenarios.
VictorZ_46
