Smart Bluetooth
While trying to run  the IDE i get this
MiTo_1583836
Contributor II
It looks similar to this issue here: Wiced Smart SDK Java issue
You probably need the 32-bit JRE version as well.
MiTo_1583836
Contributor II
Thank you very much!! it worked!!
