In BLEPROFILE_DB_PDU, there is a field called 'header'. I looked through several sample codes, but did not find any use of header. Could anyone explain what does this 'header' filed do? Thanks !
asridharan
10 comments on KBA 5 comments on KBA First comment on KBA
Layers below GATT need that extra byte for its header, so BLEPROFLE_DB_PD pre-allocates this byte.
asridharan
