Smart Bluetooth
SuLe_1710756
Contributor
Hi maxsong,
Our customer is considering to use serial flash to store user data. Could you confirm if customer is possible to use part number like attached files?
Sung-Mok
Hello Sung-Mok Lee,
Our SFLASH Drivers follow the command set of the Macronix Serial FLASH:
MX25U4033EM1I-12G.
From their manual:
http://www.macronix.com/Lists/DataSheet/Attachments/2641/MX25U4033E,%201.8V,%204Mb,%20v1.8.pdf
You have to make sure you can follow this command structure.
JT
