JaHu_1711326
First like received First like given Welcome!
In general, the device's name is defined in the field "local_name" of the data structure BLE_PROFILE_CFG and launched by the function "bleapp_set_cfg".
If I will identify the different device's name in the same firmware, how to change the device's name by function call?
Thanks!
Jack Huang
ArvindS_76
See hello_sensor sample app, in particular:
    else
        // total length should be less than 31 bytes
        BLE_ADV_FIELD adv[3];
        // flags
        adv[0].len     = 1 + 1;
        adv[0].val     = ADV_FLAGS;
        adv[0].data[0] = LE_LIMITED_DISCOVERABLE | BR_EDR_NOT_SUPPORTED;
        adv[1].len     = 16 + 1;
        adv[1].val     = ADV_SERVICE_UUID128_COMP;
        memcpy(adv[1].data, db_pdu.pdu, 16);
        // name
        adv[2].len      = strlen(bleprofile_p_cfg->local_name) + 1;
        adv[2].val      = ADV_LOCAL_NAME_COMP;
        memcpy(adv[2].data, bleprofile_p_cfg->local_name, adv[2].len - 1);
        bleprofile_GenerateADVData(adv, 3);
you can use your own string instead of bleprofile_p_cfg->local_name. And you may want to write the same string to the local name characteristic too.
ArvindS_76
    else
        // flags
        adv[0].len     = 1 + 1;
        // name
JaHu_1711326
I had tried this way to set the device's name.
But, the result is still the original value of the declared config table, bleprofile_p_cfg->local_name.
JaHu_1711326
Sorry, I forgot to write back the value to bleprofile_p_cfg->local_name.
This method works well.
Thanks!
