Hi all,
I know WICED Smart doesn't have JTAG interface, debugging is done through an SWD interface. The debugger you've recommended is Segger J-Link.
A customer is asking if there is an alternative to Segger J-Link (a cheaper one). Do you know any other?
Tiago
Debug
- debugger
Per the comments at the bottom of the Help Article here: WICED Smart J-Link Debugger
It seems that any debugger could be setup in theory to work, but we have only tested using the model shown in the link above.
I believe others have used the lower cost versions of the J-Link models here with success: SEGGER - The Embedded Experts for RTOS and Middleware, Debug Probes and Production Programmers
