02:51 AM
Jan 07, 2014
02:51 AM
HelloMaster(Android APP) is trying to connection to slave(beacon), but sometimes master read the slave
- accomplish
- advertisement
- advertisements
- android
- application
- bcm920732
- beacon
- board
- chance
- checking
- client
- connectable
- correct
- data
- database
- devices
- discovery
- evaluation
- explain
- gatt
- implemented
- implementing
- included
- issue
- make
- note
- null
- packet
- perform
- peripheral
- places
- profiles
- reading
- response
- role
- scan
- sdks
- send
- server
- service
- side
- situation
- standard
- team
- test
- typical
- understanding
- uuid
- valid
- work
07:02 AM
Jan 07, 2014
07:02 AM
Which one of the SDKs included profiles are you using to test your application? Which evaluation board are your using? BCM920732 Tag board?When you have a chance, please explain what you are trying to do and I will work with the SW team to help resolve the issue.Typically a beacon does not possess any services and might not be even connectable. Its my understanding that the typical role of a beacon is to send advertisements which contain information. Is this what you are trying to accomplish? Please note that advertisement data can be included in 2 places, the advertisement packet itself and within a scan response. Make sure that on the Android side you are checking for the correct data. If you are implementing a standard peripheral devices, weve never seen a situation where the client cannot perform a GATT service discovery if the server has a valid database implemented.
07:02 AM
Jan 07, 2014
07:02 AM
