Production Programming with EEPROM of BCM20737-TAG3
I faced below error on production programming with eeprom running Wiced smart 2.2.1
I found below link:
http://community.broadcom.com/message/8001#8001
I modified below but It didn't do the trick. I got same error message.
ENTRY "PMU Crystal Warm up Time"
  "Crystal warm up time" = 5000
Can I burn hex image into eeprom by broadcom's Bluetool ?
Thanks in advance.
Victor.
BoonT_56
First of all, the "crystal warm-up" issue is only applicable to SIP module, and not SoC. I assume you are working with module.
Can you remove "-NODLMINIDRIVER" and replace it with "-DLMINIDRIVERCHUNKSIZE 251" to chipload.exe and repeat the download again?
Lastly, please execute all these trials on the tag3 to minimize your module losses.
BoonT_56
It works well. boont!.Thanks a lot!!!
I have one more question.
We want to implement GUI-production tool in our product process.
If not broadcom's Bluetool, Could you explain how to set up our GUI-EEPROM tools ?
