Is it possible to configure a GPIO as open-drain? It doesn't seem like this configuration is allowed through the SDK (2.0) at the moment. Will it be added in the future?
Would the following workaround accomplish open-drain functionality?
-Configure GPIO as output enable and set low when signal needs to be low.
-Configure GPIO as output disable (so that it is high-Z) and allow external pullup to set the signal high.
Mike
Yes, this will work, though you might want to disable both input and output for high-Z.
If I'm not mistaken, IO like the LEDs, Serial Ports, etc. are already open drain and the pull-ups pull the signal high while the HW drives it low (i.e. never drives high, but floats the output pad leaving the pull-up to pull the line high).
I will need to check with the team to confirm that all of the IO is open drain.
