SaCo_2181666
First like received
Hi all,
I'd like to implement a JustWorks pairing procedure without bonding on my BCM20736S peripheral (no input no output capability). I know that it may be recommended to lower the TX power until pairing is done, and set it back to normal level upon pairing: is this achievable with Wiced SDK (I mean, any pairing callback to implement where to change TX power)?
Moreover, how to mark as "authenticated access needed" some Read and/or Write characteristics with JustWorks pairing?
Please, is there any Wiced example to have a look into? I need just basic hints and SDK APIs to be used for my purpose.
Thanks in advance for any help.
Sabino
AnjanaM_61
Hi Sabino,
A: For Just works pairing :
Please recheck if below points are taken care in your project :
1. /*.encr_required                  =*/ 1,   // In BLE_PROFILE_CFG , this field should be enabled
2. If peer device is not initiating pairing process, call  lesmp_sendSecurityRequest(); function in your BLE connection call back function.
You may refer to hello_sensor , hello_client examples available in WICED SMART SDK
B: For Tx power :
Use the APIs blecm_setTxPowerInADV (during advertisement )blecm_setTxPowerInConnection (during connection ) for setting the desired Tx power . Tx power range details are available here : Power level granularity in blecm_setTxPowerInConnection() and blecm_setTxPowerInADV()
C: how to mark as "authenticated access needed"
You need to set the property label in the GATT DB as per application requirement. Please refer to Reference link 3
Please also refer:
1. WICED Smart User's Guide
2.  https://www.cypress.com/documentation/application-notes/an220929-getting-started-ez-ble-wiced-module...
3. How to Write WICED Smart Applications
4. WICED Smart Quick Start Guide (SDK 1.x and TAG2 Board)
Anjana
AnjanaM_61
Hi Sabino,
B: For Tx power :
Please also refer:
Anjana
Hello Anjana,
Thanks for your reply. I gave a look to hello_sensor , hello_client examples and found a way to perform a JustWorks pairing with an App.
Sabino
