Currently I am using a wiced sense tag, but I am not able to develop anything on it and not able to debug it as well. Can you suggest me any other development kit for wiced BLE ?
BCM92073X_LE_KIT
Looks like Avnet has them in stock, as do other franchised disties: Order Parts Online, view Manufacturer Datasheets at Avnet Express
The HW User's Manual is here: Hardware User Guide (SDK 2.x and TAG3 Board)
The WICED Smart Quick Start Guide (SDK 2.x and TAG3 Board) also uses this board for reference.
BCM92073X_LE_KIT
Is Wiced smart sdk is related to both Bluetooth and wi-fi both or a specific one?
Wiced Smart SDK is for Bluetooth BLE only.
For Wiced WiFi, we have another dedicated SDK.
Does Tag3 eval board (part number: BCM92073X_LE_KIT) have inbuilt sensors like wiced sense kit?
Is there any app/project available, which will help me to understand Tag3 eval board (part number: BCM92073X_LE_KIT) working?
The tag3 EVB does not have any on-baord sensors.
We always recommend the "hello_sensor" app as the starting point for any development.
Do check out the tag3 user guide and HW interface guide within the SDK in the "Doc" folder for more information on tag3.
Wiced Sense is NOT meant to be a development too. You should acquire the Tag3 eval board (part number: BCM92073X_LE_KIT) for your development board. You may contact Avnet (India) for ordering information.
Check out the below quick-start guide.
Can you suggest me which code should I refer for the Bluetooth connection between BCM92073X_LE_KIT board and other one
Take a look at the Hello_Client and Hello_Sensor sample applications.
