Smart Bluetooth
wewu_1392881
New Contributor II
just want to confirm whether there is an EEPROM in BCM20737S? i check the 20737 data sheet and only found it has EEPROM interface.
MichaelF_56
Yes, there is 512 Kb of EEPROM included on the SIP module, which leverages the BCM20737 in die form.
Take a look at the block diagram there on the first page of theBCM20737S Bluetooth Low Energy SiP Module Technical Reference
I think you may be confusing the BCM20737 SoC with the BCM20737S SIP module.
The BCM20737 (BCM20737 SOC Data Sheet) has just the EEPROM interface.
MichaelF_56
Just clarifying that it's 512 kb (kilo bits) = 64 kB (kilo bytes).
Cheers,
Gil
MichaelF_56
Correct.
I think one of the developers responded to your specific question in the other thread that you created here: Re: Accessing the 512 kb (64 kB) EEPROM in the 20737S module
