I am using BCM20737s and would like to send my device ADV visible for all devices, but could only connect to the specific set of central devices.
is this possible?
MichaelF_56
I think passkey pairing will work for what you are trying to accomplish (user of central will need to enter a key)
You can set this up with the Hello_Client and Hello_Sensor samples apps from the SDK.
From WICED-Smart-SDK/Apps/hello_sensor/hello_sensor.c:
// Uncomment the following line to enable passkey pairing. Change passKey[] below to the desired key.
// #define PASSKEY_PAIRING
#ifdef PASSKEY_PAIRING
//passkey=123456
Using a whitelist may be another option, but you will need to know in advance the BD_ADDRs of the centrals: Adding and removing master nodes to a whitelist running on a peripheral device
Directed Advertisements could be another option: Directed Advertising
MichaelF_56
//passkey=123456
OK, thanks a lot.
