Hello, this is Taka, I have a question.
I want to use the puart interrupt and reading some documents.
I hit a discussion of using puart interrupt
here
and there are some macro in the code.
When I wrote this code as the above discussion,
P_UART_WATER_MARK_RX_LEVEL (1);
I got an error as following.
'Symbol 'dc_ptu_uart2_rfl_adr' could not be resolved'
I checked "WICED Smart™ v2.1.1 - API Reference Guide" and following is in the guid.
#define P_UART_WATER_MARK_RX_LEVEL(x) UART_REG(P_UART_WATER_MARK_RX_ADDR) = x
But there is no description of UART_REG(xxx) , I have no idea to fix them...
How sould I do? Do I have to do someting to use the macros?
I just put
#include "puart.h"
at the top of my code.
Peripherhal UART
Ignore the error, this is shown on IDE, since Eclipse cannot link to the source files and locate. You would not see this error during building your application.
thnx
vik86
Thank you for your reply, but my problem is different.
My problem is that I can not use the "Macro" at all.
When I use a macro like this,
an error is showed like this.
This is the screen shot.
I included puart.h.
There is a define as following in the puart.h .
#define P_UART_FLOW_CONTROL_WATER_MARK_ADDR dc_ptu_uart2_rfc_adr
There is a difinition of "dc_ptu_uart2_rfc_adr" in "20732mapa1.h". So I tryed to include this mapa file, but I couldn't.
thnx
vik86
I could compile it even there are some error on the IDE...orz
Thank you for your infomation.
I spent all night for this but all I have to do was that just clicking the MakeTarget.
Good night!
Taka,
