JaHu_1711326
First like received First like given Welcome!
I used the below to set up PUART flow control,
     puart_selectUartPads(((bleprofile_puart_p_cxfg->rxpin / 16) << 5) | (bleprofile_puart_p_cfg->rxpin % 16),
               3, 1);
     puart_init();
     puart_flowOn();
and the WP pin of my test platform is set to P32.
There are only 16 bytes of data received and some data lost when transferring over 16 bytes of data.
The RTS pin of the PUART seems not work.
Thanks!
Jack Huang
BoonT_56
There is a discussion here that explains why RTS doesn't work...
Need clarification on PUART RTS/CTS flow control support
BoonT_56
