Smart Bluetooth
user_2195381
New Contributor II
Could you tell me how to change the device name characteristic from GATT database to other device name stored in NVRAM
const UINT8 gatt_database[]= // Define GATT database
// ***** Primary service 'Generic Access'
    //<Name>Generic Access</Name>
    //<Uuid>1800</Uuid>
    //Service handle: HDLS_GENERIC_ACCESS
    //Service UUID: UUID_SERVICE_GAP
    PRIMARY_SERVICE_UUID16 (HDLS_GENERIC_ACCESS, UUID_SERVICE_GAP),
    //<Name>Device Name</Name>
    //<Uuid>2A00</Uuid>
    CHARACTERISTIC_UUID16 (HDLC_GENERIC_ACCESS_DEVICE_NAME,
                           HDLC_GENERIC_ACCESS_DEVICE_NAME_VALUE,
                           UUID_CHARACTERISTIC_DEVICE_NAME,
                           LEGATTDB_CHAR_PROP_READ,
                           LEGATTDB_PERM_READABLE,
                           6),
    'a','b','c','d','e','f',
APPLICATION_INIT()
    bleapp_set_cfg((UINT8 *)gatt_database,
                   gatt_database_len,
                   (void *)&homedoor_cfg,
                   (void *)&homedoor_puart_cfg,
                   (void *)&homedoor_gpio_cfg,
                   homedoor_create);
    BLE_APP_ENABLE_TRACING_ON_PUART();
void homedoor_create(void)
     if (bleprofile_ReadNVRAM(VS_BLE_HOST_LIST, sizeof(homedoor_devicename), (UINT8 *)&homedoor_devicename))
          @// I will want to change device name "abcdef" to homedoor_devicename. How I can do it ????????????????
