Could you tell me how to change the device name characteristic from GATT database to other device name stored in NVRAM
const UINT8 gatt_database[]= // Define GATT database
// ***** Primary service 'Generic Access'
//<Name>Generic Access</Name>
//<Uuid>1800</Uuid>
//Service handle: HDLS_GENERIC_ACCESS
//Service UUID: UUID_SERVICE_GAP
PRIMARY_SERVICE_UUID16 (HDLS_GENERIC_ACCESS, UUID_SERVICE_GAP),
//<Name>Device Name</Name>
//<Uuid>2A00</Uuid>
CHARACTERISTIC_UUID16 (HDLC_GENERIC_ACCESS_DEVICE_NAME,
HDLC_GENERIC_ACCESS_DEVICE_NAME_VALUE,
UUID_CHARACTERISTIC_DEVICE_NAME,
LEGATTDB_CHAR_PROP_READ,
LEGATTDB_PERM_READABLE,
6),
'a','b','c','d','e','f',
APPLICATION_INIT()
bleapp_set_cfg((UINT8 *)gatt_database,
gatt_database_len,
(void *)&homedoor_cfg,
(void *)&homedoor_puart_cfg,
(void *)&homedoor_gpio_cfg,
homedoor_create);
BLE_APP_ENABLE_TRACING_ON_PUART();
void homedoor_create(void)
if (bleprofile_ReadNVRAM(VS_BLE_HOST_LIST, sizeof(homedoor_devicename), (UINT8 *)&homedoor_devicename))
@// I will want to change device name "abcdef" to homedoor_devicename. How I can do it ????????????????
SDK 2.X
Security
WICED Sense
Hello Tsung-Yu,
Have you seen this post:
How to change the device name?
To change the device's name dynamically
JT
Hello Tsung-Yu,
JT
I have seen the post
I think it will be the answer for my issue.
Thanks !
