Smart Bluetooth
wihu_4601901
New Contributor
Recently, I need to choose a Bluetooth Module which can support Serial Port Portfolio or it has solution to create serial profile.   Also, it needs to have RTS pin as well as bidirectional UART. Otherwise, I think I would need to build a custom profile which can link to the serial port.
Could anyone gives a few suggestion and provide some links of relevant information?   Many thanks!
DheerajPK_41
Please check below link. All the BT+BLE chips should support serial profiles. Based on your requirement please select a chip and then from then below link you can select an appropriate module.
https://www.cypress.com/products/ble-bluetooth
https://www.cypress.com/products/ble-bluetooth#tabs-0-bottom_side-3
Please go through "WICED-based EZ-BLE and EZ-BT Modules" and select appropriate module for your application.
https://www.cypress.com/products/ble-bluetooth#tabs-0-bottom_side-6
-Dheeraj
DheerajPK_41
-Dheeraj
