Similar to the thread here: No GATT-Database if bleprofile_Init()
I am runing into this issue as well. The database and the app are completely generated by the designer, yet it won't run. All I am doing is creating a device with a generic heart rate monitor service and enabled notifications. Below is the GATT database.
const UINT8 gatt_database[] = // Define GATT database
/* Primary Service 'Generic Access' */
//<Name>Generic Access</Name>
//<Uuid>1800</Uuid>
//Service handle: HDLS_GENERIC_ACCESS
//Service UUID: UUID_SERVICE_GAP
PRIMARY_SERVICE_UUID16 (HDLS_GENERIC_ACCESS, UUID_SERVICE_GAP),
/* Characteristic 'Device Name' */
//<Name>Device Name</Name>
//<Uuid>2A00</Uuid>
CHARACTERISTIC_UUID16 (HDLC_GENERIC_ACCESS_DEVICE_NAME,
HDLC_GENERIC_ACCESS_DEVICE_NAME_VALUE,
UUID_CHARACTERISTIC_DEVICE_NAME,
LEGATTDB_CHAR_PROP_READ,
LEGATTDB_PERM_READABLE,
8),
'B','a','t','m','a','n','_','1',
/* Characteristic 'Appearance' */
//<Name>Appearance</Name>
//<Uuid>2A01</Uuid>
CHARACTERISTIC_UUID16 (HDLC_GENERIC_ACCESS_APPEARANCE,
HDLC_GENERIC_ACCESS_APPEARANCE_VALUE,
UUID_CHARACTERISTIC_APPEARANCE,
2),
BIT16_TO_8(APPEARANCE_GENERIC_HEART_RATE_SENSOR),
/* Primary Service 'Generic Attribute' */
//<Name>Generic Attribute</Name>
//<Uuid>1801</Uuid>
//Service handle: HDLS_GENERIC_ATTRIBUTE
//Service UUID: UUID_SERVICE_GATT
PRIMARY_SERVICE_UUID16 (HDLS_GENERIC_ATTRIBUTE, UUID_SERVICE_GATT),
/* Primary Service 'Heart Rate' */
//<Name>Heart Rate</Name>
//<Uuid>180D</Uuid>
//Service handle: HDLS_HEART_RATE
//Service UUID: UUID_SERVICE_HEART_RATE
PRIMARY_SERVICE_UUID16 (HDLS_HEART_RATE, UUID_SERVICE_HEART_RATE),
/* Characteristic 'Heart Rate Measurement' */
//<Name>Heart Rate Measurement</Name>
//<Uuid>2A37</Uuid>
CHARACTERISTIC_UUID16 (HDLC_HEART_RATE_HEART_RATE_MEASUREMENT,
HDLC_HEART_RATE_HEART_RATE_MEASUREMENT_VALUE,
UUID_CHARACTERISTIC_HEART_RATE_MEASUREMENT,
LEGATTDB_CHAR_PROP_NOTIFY,
LEGATTDB_PERM_NONE,
2),
0x87,0x00,
/* Client Characteristic Configuration Descriptor */
//<Notification>true</Notification>
//<Indication>false</Indication>
CHAR_DESCRIPTOR_UUID16_WRITABLE (HDLD_HEART_RATE_HEART_RATE_MEASUREMENT_CLIENT_CONFIGURATION,
UUID_DESCRIPTOR_CLIENT_CHARACTERISTIC_CONFIGURATION,
LEGATTDB_PERM_READABLE | LEGATTDB_PERM_WRITE_CMD | LEGATTDB_PERM_WRITE_REQ | LEGATTDB_PERM_RELIABLE_WRITE | LEGATTDB_PERM_AUTH_WRITABLE,
2),
BIT16_TO_8(CCC_NOTIFICATION),
ReadWrite Characteristics
SDK 2.X
Smart designer is just a nifty tool that is out there, however generally the developers end up asking people to use hello_sensor GATT DB as their starting point.
Sorry it didn't work for you
Have you taken a look at hello_sensor or heart_rate_monitor? Heart rate monitor gives you random values but it does exactly what you want to do.
-Kevin
Yeah, that's what I am using now. It would be nice if the wizard got fixed in future versions, though .
